Can i push my HTT multi further?
18 Oct 2002
Bristol
My 3700 Clawhammer is at 2760mhz, htt is at 230, ht ratio is at 3 and my rams on a 166 devider so its running at 184mhz 2.0-3-3-5. Cpu voltage is 1.65 at the mo and ram voltage is at 2.6 volts. I have and asus k8n-e-deluxe and was wondering if this is the highest the htt will go, my pc just wont post if i up the htt to 232 with the settings as i stated above.
Idealy i want to keep overclocking and get my ram mhz higher, closer to 200 what it should be at, my temps arnt and issue max load at the mo is 41C. If i lower my ht ratio from 3 to 2 is that gonna help? will that loose any performance cause ive already lowered it from 4?
Any thoughts on different settings to try cause i really think this chip has a lot more in it.
Thanks
Mate it cant be the ram voltage that is causeing the problems surely, after all the ram is running below spec, ive had the ram at 2.8 and its made no difference, 232 htt just wont post.
Have you tried reducing the muliplier on your cpu and increasing the htt? 2.7ghz may be as fast as it'll go.
