Can I Run a 5900X on an X470 Aorus Gaming 7 Wifi?
i was just about to post a similar question, i have the same motherboard and would like to fit a 5800x,
i am on the latest bios but the support list says no, seems a bit odd tbh, although the support list is not up
to the latest bios revision.
What cpu do you have now, Wakadoo? I problem I read about was that updating to bios F50 or later caused the motherboard to no longer recognise chips earlier than the 3000 series. I'm currently on F31 with my 2700X, so a little cautious!
You have no worries updating the bios as it still supports your 2700x its older cpu's that's loose support due to size of the bios chip on the motherboard.
