Can I run two screens? i3 3220
13 Mar 2011
Bada Bing
I would like to run an additional screen on a rig. Specs:
Intel Core i3-3220
Intel Moccasin Peak DQ77MK
It is running one monitor at the moment over DVI and id like to connect another over DVI - is it doable?
I couldnt find a clear answer online
Thanks guys
the cpu can run up to 3 screens on certain boards:
There is conflicting info about the second DVI port being for discrete graphics
EDIT: this sheds some light
In other words, you can connect 2 displays to the motherboard and use the onboard graphics plus 2 more on the video card and have quad display
