(From my other thread Grand Theft Auto - Slowwwwwwwwwww)
I have a Dell Dimension 9200, have upgraded GFX card to ATI 5770, 4gb ram, but CPU is now bottlenecking everything.
So..... am I able to upgrade my processor, if so what should I get for about £120??
Here's the CPU-Z report -
CPU-Z TXT Report
Binaries
CPU-Z version 1.53.1
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium D 945
Codename Presler
Specification Intel(R) Pentium(R) D CPU 3.40GHz
Package (platform ID) Socket 775 LGA (0x2)
CPUID F.6.4
Extended CPUID F.6
Core Stepping C1
Technology 65 nm
Core Speed 2394.1 MHz
Multiplier x FSB 12.0 x 199.5 MHz
Rated Bus speed 798.0 MHz
Stock frequency 3400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, EM64T
L1 Data cache 2 x 16 KBytes, 8-way set associative, 64-byte line size
Trace cache 2 x 12 Kuops, 8-way set associative
L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 14.0x - 17.0x
VID range 1.116 V - 1.324 V
Chipset
Northbridge Intel P965/G965 rev. C1
Southbridge Intel 82801HH (ICH8DH) rev. B0
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Samsung (CE00000000000000)
Size 1024 MBytes
Max bandwidth PC2-4300 (266 MHz)
Part number M3 78T2953CZ3-CD5
Serial number F147709B
Manufacturing date Week 43/Year 06
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-8-11 @ 200 MHz
JEDEC #2 4.0-4-4-11-15 @ 266 MHz
JEDEC #3 5.0-4-4-11-15 @ 266 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR2
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 1024 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number VS1GB667D2
Number of banks 1
Data width 64 bits
Correction None
EPP no
XMP no
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-5-5-15-20 @ 333 MHz
DIMM # 3
SMBus address 0x52
Memory type DDR2
Size 1024 MBytes
Serial number F1477074
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
DIMM # 4
SMBus address 0x53
Memory type DDR2
Size 1024 MBytes
Number of banks 1
Data width 64 bits
Correction None
EPP no
XMP no
Monitoring
Mainboard Model 0WG855 (0x00000170 - 0x005930A0)
Hardware Monitors
Hardware monitor Radeon HD 5770
Temperature 0 48°C (118°F) (GPU Core)
DMI
DMI BIOS
vendor Dell Inc.
version 2.5.3
date 11/22/2007
DMI System Information
manufacturer Dell Inc.
product Dell DXP061
version unknown
serial 7V89K2J
UUID 44454C4C-56001038-8039B7C0-4F4B324A
DMI Baseboard
vendor Dell Inc.
model 0WG855
revision unknown
serial ..CN708296A5A4AD.
DMI System Enclosure
chassis type Tower
chassis serial 7V89K2J
DMI Processor
manufacturer Intel
model unknown
clock speed 3400.0 MHz
FSB speed 800.0 MHz
multiplier 4.5x
DMI Port Connector
designation USB1 (internal)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (internal)
port type USB
DMI Port Connector
designation USB3 (internal)
port type USB
DMI Port Connector
designation USB4 (internal)
port type USB
DMI Port Connector
designation USB5 (internal)
port type USB
DMI Port Connector
designation USB6 (internal)
port type USB
DMI Port Connector
designation USB7 (internal)
port type USB
DMI Port Connector
designation USB8 (internal)
port type USB
DMI Port Connector
designation ENET (internal)
port type Network Port
connector RJ-45
DMI Port Connector
designation MIC (internal)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation LINE-OUT (internal)
DMI Port Connector
designation LINE-IN (internal)
DMI Port Connector
designation HP-OUT (internal)
DMI Extension Slot
designation PEG
type A5
populated yes
DMI Extension Slot
designation SLOT1
type A5
populated no
DMI Extension Slot
designation SLOT3
type A5
populated no
DMI Extension Slot
designation SLOT4
type PCI
width 32 bits
populated no
DMI Extension Slot
designation SLOT5
type PCI
width 32 bits
populated no
DMI Extension Slot
designation SLOT6
type PCI
width 32 bits
populated no
DMI OEM Strings
string[0] www.dell.com
DMI Physical Memory Array
location Motherboard
usage System Memory
correction Single-bit ECC
max capacity 4096 MBytes
max# of devices 4
DMI Memory Device
designation DIMM_1
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation DIMM_3
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation DIMM_2
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation DIMM_4
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 1024 MBytes
Graphics
Number of adapters 1
Graphic APIs
API ATI OD5
API ATI I/O
Display Adapters
Display adapter 0
Manuf. API index 0
Display name \\.\DISPLAY1
Name Radeon HD 5770
Codename RV840
Technology 40 nm
Memory size 1024 MB
Memory bus width 128 bits
GPU ref clock 27000
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x174B)
Model ID 0x68B8 (0xE147)
Performance Level 0
Core clock 157.0 MHz
Memory clock 300.0 MHz
Software
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
DirectX Version 11.0
Cheers
CPU-Z TXT Report
Binaries
Processors
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processor 1 ID = 0
Codename Presler
CPUID F.6.4
Extended CPUID F.6
Core Stepping C1
Technology 65 nm
FID/VID Control yes
Chipset
Memory Type DDR2
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Size 1024 MBytes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
DIMM # 2
SMBus address 0x51
Memory type DDR2
Size 1024 MBytes
Number of banks 1
Data width 64 bits
Correction None
EPP no
XMP no
DIMM # 3
SMBus address 0x52
Memory type DDR2
Size 1024 MBytes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
DIMM # 4
SMBus address 0x53
Memory type DDR2
Size 1024 MBytes
Number of banks 1
Data width 64 bits
Correction None
EPP no
XMP no
Monitoring
Hardware Monitors
DMI
DMI BIOS
vendor Dell Inc.
version 2.5.3
date 11/22/2007
product Dell DXP061
version unknown
serial 7V89K2J
DMI Baseboard
vendor Dell Inc.
model 0WG855
revision unknown
chassis type Tower
DMI Processor
manufacturer Intel
model unknown
FSB speed 800.0 MHz
multiplier 4.5x
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
connector RJ-45
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Port Connector
DMI Extension Slot
designation PEG
type A5
populated yes
DMI Extension Slot
designation SLOT1
type A5
populated no
DMI Extension Slot
designation SLOT3
type A5
populated no
DMI Extension Slot
designation SLOT4
type PCI
width 32 bits
populated no
DMI Extension Slot
designation SLOT5
type PCI
width 32 bits
populated no
DMI Extension Slot
designation SLOT6
type PCI
width 32 bits
populated no
DMI OEM Strings
usage System Memory
max# of devices 4
DMI Memory Device
designation DIMM_1
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation DIMM_3
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation DIMM_2
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 1024 MBytes
DMI Memory Device
designation DIMM_4
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 1024 MBytes
Graphics
Graphic APIs
API ATI OD5
API ATI I/O
Display Adapters
Display adapter 0
Manuf. API index 0
Name Radeon HD 5770
Codename RV840
Technology 40 nm
Memory size 1024 MB
GPU ref clock 27000
Performance Level 0
Software
Cheers
