29 Nov 2009 at 22:34 #1 easyrider easyrider Caporegime Joined 24 Dec 2005 Posts 40,241 Location Autonomy Or do I need a TV? I was thinking of getting a new monitor and thought it may be a good idea if I can watch Sky HD on it. HDMI will work right? I just use the sound from my amp....
29 Nov 2009 at 22:38 #2 Joshy Joshy Soldato Joined 15 Jun 2009 Posts 5,016 Location London Yes it will work through the HDMI cable. It'll display the picture and sound just as if it were a 'normal' TV.
29 Nov 2009 at 23:13 #3 kylew kylew Permabanned Joined 31 May 2007 Posts 10,721 Location Liverpool HDMI will most definitely work.
29 Nov 2009 at 23:24 #4 easyrider easyrider Caporegime OP Joined 24 Dec 2005 Posts 40,241 Location Autonomy Has anyone used a DVI -HDMI Convertor? I have just bought one on the bay for 1.49 should work?
30 Nov 2009 at 00:23 #5 SMB30 SMB30 Associate Joined 16 Oct 2007 Posts 302 Location Wales easyrider said: Has anyone used a DVI -HDMI Convertor? I have just bought one on the bay for 1.49 should work? Click to expand... Will work fine but does not support sound over DVI.
30 Nov 2009 at 00:28 #6 easyrider easyrider Caporegime OP Joined 24 Dec 2005 Posts 40,241 Location Autonomy SMB30 said: Will work fine but does not support sound over DVI. Click to expand... Thats fine cheers
