- 3 Nov 2010
I know that the actual cables need to be changed but what about the actual lead that power's the psu ie the kettle type lead.
"Kettle" leads are normally rated 5A, 10A or 13A there are no 20A ones.as long as you dont
get a new psu thats much more powerful
the gauge/and amp rating of the kettle lead can vary
anywhere from 18 awg/10A
to 12 awg/20A
Even 5 Amps is good for 1150 watts.
It'll be fine my dude.going from 750w to 850w
Should be absolutely fine then, but might just be worth checking what fuse you power cable has for future referencegoing from 750w to 850w
Glad I found this thread the other day as I never considered the Amp rating before and my cables are all over the place. Turns out Amazon sent me an EU product so now I have to find a cable with the right Amps to fit! Going to assume 5A is plenty for 850W, then I just need to sort out why my monitors have 10A cables..."Kettle" leads are normally rated 5A, 10A or 13A there are no 20A ones.
I'd go for 10A for an 850W PSU (850W being what it can supply - it will draw more than that from the wall)Glad I found this thread the other day as I never considered the Amp rating before and my cables are all over the place. Turns out Amazon sent me an EU product so now I have to find a cable with the right Amps to fit! Going to assume 5A is plenty for 850W, then I just need to sort out why my monitors have 10A cables...
Oh that is a good point, it's the supply not the demand. That might explain why the EU plug was 16A. Seemed excessive but at 80% efficiency it's going to be over 5A.I'd go for 10A for an 850W PSU (850W being what it can supply - it will draw more than that from the wall)
