Can i use my pc as a monitor for my xbox using the s video input on my 4870?
17 Mar 2007
Plymouth
As per title really, got this cable that i can use to connect the xbox to my 4870. If so what software would i need to use? (i can connect the sound output directly to my amp so i only need the pc to deal with video)
I'm assuming you've looked into this but I thought it was worth mentioning anyway: Can you not just hook your xbox up to yout monitor directly?
They support both HDMI and VGA so unless you monitor is just display port or DVI this should be possible.
