Can I use surgical solution to clean screen and cpu paste?
29 Mar 2007
Manchester
Hello :D
I found a bottle of surgical solution (Ethanol and Methanol). Can I use it for both cleaning paste off cpu's and for lcd screen cleaner?
Thanks.
What do you use?
sounds pretty good for cleaning the CPU.
i'd try a tiny amount on the corner of the screen to make sure it doesn't mar the surface, but it shouldn't. i use isopropyle alcohol for cleaning my screen.
