I use a combination of them.
Adaware
SpyBot S&D
NoAdware
Spyware Doctor
To be honest, I am seriously considering dropping S&D because its not that much use anymore.
Adaware is perhaps my favourite due to its immense speed over the others, but in terms of Power, its probably Spyware Doctor thats the one thats ahead of the rest.
Using more than one spyware app is NEVER overkill.
I can run any 3 of these and I can bet that the 4th one will probably find somethign that the others missed ( Not really, but definitely if I have not run a check in a few weeks )
As for not going to iffy sites or downloading suspicious files etc, this does not mean that doing everythign properly will mean that you wont get spyware.
I did a small test several months ago, and installed XP onto a PC, and got it connected to the internet, I ran Adaware and it found 9 entries... Now, this is nothing as there are this much on a fresh install anyway, but I left the PC running for 5 days, came back and I found 35 entries... Where did they come from?
firewallblocked said:
Norton Anti-virus 2005 & 2006 created to boost the sales of ddr memory.
