Can i use two PSU's to decrease load?
9 Jul 2004
Nottingham
Yesturday i recieved my new x1950 Pro 512. However, i only have a 400W X-Pro PSU with 20amps on the 12v rail. It says on the box "450W+ and 24amps on 12v rail or more recommended"
At the moment i have my processor (which i want to overclock quite a bit back up to 2.6ghz), 2 standard IDE DVD-RW and CD-ROM drives, 1xIDE 40GB Hard Drive, 1x250GB SATA Hard Drive and a floppy.
This has me worried that the PSU could blow at any minute, so i was wondering if i could use and older PSU (X-Pro 350W) to power the 2 CD-Drives and the one hard drive (or both if i can find the sata power adapted for the PSU). My only concern is that these items of hardware will take a risk with them not being connected to the main motherboard and could be dangerous and have little protection if anything does go wrong.
Can it be done safely? :)
Many Thanks.
That's the only reason I can think for not doing it... But at the end of the day if your PSU's gonna blow then components won't have a lot of protection regardless of what else is plugged into the PSU :-\
I wouldn't feel comfortable doing it, but I'd probably feel more comfortable doing that than running the whole lot on the 400w PSU :p Never tried it myself, but as a temporary solution I can't think of any reason not to :confused:
EDIT: Actually, the second PSU won't turn on will it..? Unless it's plugged into a mobo with an on switch you could press? It's starting to sound like too much of a bodge job tbh :p Just get another PSU and don't put the computer under too much load in the meantime imo!
You want one of those.
You can get a Y splitter cable that plugs into the mobo and the 2 psu's i have had a quick google for them but can't find one anywhere but i KNOW they exist, this would make both psu's power up when the power button is pressed on the case.
Might be easier to buy a beefier psu though :confused:
Edit yup thats what i was looking for :p
i run 2 psu's, more for braggin rights that anything else.
what i did to get the second psu to power up and down with the system was to put a relay onto the 5v line of the primary psu and "power on" line of the secondary.
works like a dream by using the relay the 2 power supplys are electrically isolated from each other. therefore the 2 psu's are acting as independant power supplies.
Concorde Rules said:
Is it stable at stock? If it is then try overclocking again.
Because tbh that PSU is enough IMO.
And if it isn't then one larger PSU > multiple PSUs
Yup, perfectly stable so far, but clocking the CPU is my main concern as i know that draws out more power. I think ill get a new PSU then asap :)
Thanks for the help anyway :cool:
