Pretty much self explanatory in the title - bought this for my Ryzen build on MM:
https://www.overclockers.co.uk/cors...hannel-kit-red-cmk16gx4m2b3000-my-451-cs.html
Silly should have checked for compatibility but thought this isn't such a problem anymore.
Running on MSI B350 Tomahawk with Ryzen R5 1600 - the memory isn't on the compatibility list (strangely the 3200mhz ver is but not the 3000mhz). The memory boots up fine but it took me ages to get it to boot up to at just 2666mhz and neither of the XMP 2800 or 3000 would load.
I've ran a memtest (the windows 10 one) and it said there are issues with it.
The memory apparently ran fine on the previous owners Intel setup.
Will it be giving errors in memtest simply because of the motherboard incompatibility ?
Any thoughts appreciated but I guess easiest way to test is to get another set of ram and check if that works fine.
