Can it be done gaming build for £600 inc TFT
22 Oct 2010
East Yorkshire
Can you spec me a £600 build to play bf3 at full HD inc tft that needs to be hd , can it be done ? not bothered about amd and intel had a 965 and loved it
Assuming you don't need any peripherals or OS. Hows this look.
HIS ATI Radeon HD 6870 1024MB GDDR5 PCI-Express Graphics Card with DIRT3 & Deus Ex PC Games £139.99
(£116.66) £139.99
(£116.66)
Asus VE228H 22" Widescreen LED Multimedia Monitor - Black Asus VE228H 22" Widescreen LED Multimedia Monitor - Black £119.99
(£99.99) £119.99
(£99.99)
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £89.99
(£74.99) £89.99
(£74.99)
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £79.98
(£66.65) £79.98
(£66.65)
OCZ ZS Series 550W '80 Plus Bronze' Power Supply OCZ ZS Series 550W '80 Plus Bronze' Power Supply £49.98
(£41.65) £49.98
(£41.65)
BitFenix Merc Beta Gaming Case - Black BitFenix Merc Beta Gaming Case - Black £32.99
(£27.49) £32.99
(£27.49)
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £29.99
(£24.99) £29.99
(£24.99)
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £23.99
(£19.99) £23.99
(£19.99)
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
(£14.16) £16.99
(£14.16)
Sub Total : £486.57
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £20.10
VAT is being charged at 20.00% VAT : £101.33
Total : £608.00
i3 faster than AMD Phenom II 955.
really need a Quad Core ;)
Money don't grow on trees in OP's backyard :p
The i3 2100 is a very decent CPU that's faster than Core2Quad or Phenom II X4 at 3.6GHz on gaming performance, despite it is only a dual-core. More cores is not always better or faster...Bulldozer have already proved this.
but bf3 uses 4 cores, hell my 4ghz 955 was 98% usage majority of the time on all high settings @ 1080...
Actually BF3 uses at least 6 cores as far as I know.
i3 2100 is AS FAST AS a Phenom II X4 at 3.7-3.8GHz EVEN in games that use 4 cores or more, but with just half the power consumption under load (65W TDP vs 140W TDP+) and doesn't require a 3rd party CPU cooler to keep the temp under control. In games that use less than 4 cores (majority of the games only uses 2~3 cores), the overclocked Phenom II X4 is SLOWER than the i3 2100.
just to throw a spanner in the works what about the amd 3850 cpu apparantly its best cpu under £100 as far as reviews go and is better value than any i3 as isnt far behind
It's the best CPU for under £100 for people that want to game on PC but can't afford decent graphic card. CPU wise it is quite a lot slower than the 2100.
