I have:-
E6400 @ 3.6 1.6v - 35 idle, 62 load on both cores
P5N-E
8800 GTS @ 600/2000 (just started playing with the gpu clocks).
I'm sorely tempted to get the Danger Den block and plumb it into my current WC loop which consists of:-
Eheim 1250
Bayres
Cathar Cascade, Delrin Top
2x120mm Radiator (unknown manufacturer, have owned for 5 years now) w/2 120mm pulling and 1 pushing air.
With the fans at 7v after a couple of hours at load the radiator is still cool to the touch. I think there is enough capacity in the rad to dissipate 250-300w of heat, but before i go and splash out £100 on the block i'd like to get some idea if itll handle the load.
P5N-E
Eheim 1250
Bayres
Question is is it worth also getting a new pump?
