- 7 Jun 2009
Hi - i looking at my next upgrade, which feels like it should be my monitor (currently running 1080p).
Will my current setup be up to the job at 1440 (I expect not to be able to max everything out)? I can probably upgrade my GPU further down the line (seems overkill to upgrade it now for 1080).
If it helps, I was looking at this one: http://www.overclockers.co.uk/showproduct.php?prodid=MO-060-DE&groupid=17&catid=1120
What are your thoughts . . .
Thanks in advance
Thanks in advance
