Can no longer run DDRII dual channel, but both stick+sockets run fine seperately
28 Jul 2008
Thanks for taking the time. I had a corrupt version of windows XP 32 bit and have since installed windows 7 64 bit. When I still had XP, I couldn't get the PC to boot up in any mode. I tried reseting my BIOS to the 'default optimal settings' and have since not been any to run my Kingston 2x2gb dual channel RAM (HyperX DDR2-800 PC6400 4-4-4-12), it doesn't POST. But strangely both sockets will work with either stick of RAM when used alone. Also, my old dual channel DDR1 RAM will work as well.
The motherboard is an ASRock 4 core dual SATA-2, a crossover board I bought to keep my DDR1. Twice since running Windows 7 the PC has crashed to the bluescreen message 'BAD_POOL_DATA' and once to a blue screen with a loud humming sound but no message, over the course of a few days. But it seems this could be related to any number of changes I've made to my system over the last few days, searching suggests it might be a driver problem.
Presumably by checking 'deafult optimal settings' in the BIOS I caused the problem. I have tried setting the CAS frequency, and BUS size instead of leaving them on auto, changing the voltage, and setting the two sticks to run in single channel mode, still, it won't POST. I didn't want to mess around with the settings anymore until getting some suggestions, as I've only a pretty basic understanding of hardware and would like to be able to at least keep using one 2gb stick. I can't find any drivers from the ASRock site for windows 7 systems and this motherboard. This problem began before installing windows 7 so I guess that can be ruled out.
Any suggestions? Thanks then.
was your system overclocked prior to resetting the bios?
i fiddled a lot with my osrock board bios, returning to default etc. i noticed that not all settings were returned when using performance optimal etc.
id try clearing cmos (jumper on the mobo)
will return the bios to original setup and go from there
I had experimented with overclocking my graphics card recently just to see if I could, but it's a Radeon 4890, so there was no need for it. It was definitely not overclocked at the time of the problem, nor was anything else.
I'd tried flashing the CMOS, no change. If not, 2gb of DDRII seems to be just about enough for most high-end gaming right now, perhaps I should just see how long it can hold pace, then upgrade to a new board. God knows why people bother buying 8GB of DDRIII.
Thanks for the suggestion.
