My first laptop has been sitting in my old laptop bag for the last couple years. Since I started getting into computers and learning more about them, I think I have decided to dissect this one, just to explore it. I'm not sure what happened, but the screen went blank, it wouldn't turn on anymore and after removing the hard drive and hearing some lose parts inside the hard drive moving around I determined it was broken. So It's been sitting since and I pulled it out of the closet and determined that this will be my little test project or lab experiment.
I purchased it in 2007 it is a HP dv6000 special edition. Can I dissect this and upgrade some of the parts or maybe just buy replacement parts?
I would think that the hard drive could be changed, I would think I would be able to purchase a 2.5inch internal hard drive and as long as it is SATA it should work.
I'm not sure what part of the laptop is actually broke, but lets say it needs a new motherboard. are replacement laptop component available like on amazon or newegg? I'm assuming it's not like a PC where you can swap out components for other components, but in theory I think it would be nice to rip the old laptop apart and purchase a new motherboard, ram, processor, and hard drive. Not go crazy with pricing just enough to get it working again and put a little bit of modern technology inside it.
Still as a part of an experiment you may try to re-animate it, though the problem is that it's much harder to find parts that will suit your device than that of a PC.
