Hi guys,
I built this system 5 years ago now, although thats easy enough to do. I had a go at overclocking it, but i found what ever i tried to do to overclock it was never ever stable. So i just gave up set to optimal settings and left it as it was and its been realiable ever since and means i gave up with pc games i felt i didnt need a performance boost or it was too slow.
Lately I have got back into PC gaming and been playing CSS a lot again again
but in a 32 man server im really suffering 20-30fps in firefights. Ive messed around with lowering the detail etc but to be honest doesnt make much difference if any at all so i may aswell play with medium/high settings.
I done a search on this forum about overclocking my system again and came across a few posts saying they have been running my exact setup at 75-100% overclocked for years with no problem. Means i have windows 7 now i thought id give it a go and see if it was any more realiable.
My spec is;-
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
GeIL 3GB (3x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit >>>1 GB STICK FAILED!<<<
Scythe Ninja Plus Rev.B Heatpipe CPU Cooler
HIS ATI Radeon X1900 XT ICEQ 3 SILENT Heatpipe 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express)
Here is a pic of the bios.
Uploaded with ImageShack.us
I have increased the memory so currently its running at 2100mhz but ive tried at 2400mhz and cs was running sweet so i shut down and tried at 2600mhz as ive read this is the "norm" for overclocking for this chip. The system wouldnt even boot up after it posted. So i turned it back down to 2400mhz and css was running roughly 20fps better than previously at stock. But then when i was browsing the net later on it froze up on me. I checked the CPU temp as soon as i rebooted and it was only running at 40oc. Also it seems that my gfx card is running at 90-100oc when playing cs even though it has been tuned down in CCC manager. Any reason why this is happening? age of the system.
If someone could give me tips to get a little bit more out of this system to last me a few more months i would be over the moon!!
Thanks guys!!
Dean
My spec is;-
Thanks guys!!
Dean
