Can someone explain to me please how 3 pin and 4 pin PWM fans work in conjunction with a fan control
26 Sep 2013
West End, Southampton
Hi guys.
Currently putting together a little build project. Got the Corsair 780T pre-order, also got 4 SP120 PWM High Performance for push/pull config on a future purchase on the H105 when it comes back in Stock. Now the case already has two LED AF120s in the front which I'm guessing are hooked up to the fan controller on the front of the case. My question is, the 4 SP120 PWM high performance fans I have, I want to be able to control them via a Fan Controller which I'm planning on having in one of the drive bays. The fan controllers I've looked at though, seem to have 3 pin connectors for the various fan channels. I thought you can only control voltage and monitoring with 4 pin PWM fans??? Would I need a 4 pin to 3 pin adaptor so I can hook up the 4 fans on my rad to the Fan Controller?
thanks in advance
ok cheers setter. Isn't that a little ball ache having to go in to the bios when fan speeds need to be upped though, mid gaming session? The reason I said about the controller, I thought that would be the easiest, and quickest way to alter speeds on the fly to control temps?
