Can someone explain voltage settings to me?
27 Feb 2009
Hinckley
Hi all,
having a conundrum trying to get my ddr2 ram to run at 800mhz on my board. Both the ram and MB natively support (supposed to) 800mhz, however it needs to be set manually in the bios.
When I do this however, and open up cpu-z my cpu voltage is around 1.2-1.3 - whereas usually it is around 1.1-1.2.
I'm not exactly sure why it affects cpu voltages when simply changing the ram speed, can any one explain whether i have to set cpu voltages manually and what it should be set to?
Thanks
Edit;
I should add that i set it manually to 1.125 and all works ok, but im worried it may be too low.
http://www.corsair.com/_datasheets/TWIN2X4096-6400C4DHX.pdf
It does state 2.1v to run at 4-4-4-12 800mhz, however i want to make sure the cpu voltage is correct before making any changes to ram.
@egnshane I've set vcore at 1.100v (lowest available setting on my MB) How do i use prime 95? I've just run it and hit ok to run the 'blend' test. Ran for 5 mins completed 2 tests with 0 errors for each core. Would that be sufficient enought to keep at the voltage im running?
No you want to run it for 2 - 3 hours to have an indication its stable, its best to have the voltages as low as possible. It keeps heat down.
if your not overclocking leave cpu voltage on auto,
setup your ram: voltage 2.1v, timing: 4-4-4-12 speed:800mhz
im not sure but the power circuitry on your board might not be that good, it might be leaking voltage to the cpu because the ram voltage is quite high + your running 4 sticks.
i personaly say you have nothing to worry about, aslong as it is stable and your temps are within spec.
