I've been looking at motherboards and memory and came across details like this "4 x DIMM, Max. 128GB, DDR5 5200MHz upto 6400MHz (OC)" or supports 7600+(OC)/ 7200(OC)/ 7000(OC)/ 6800(OC)/ 6600(OC)/ 6400(OC)/ 6200(OC)/ 6000(OC)/ 5800(OC)/ 5600(OC)/ 5400(OC)/ 5200/ 5000/ 4800
Now the part I'm confused with is the "5200MHz upto 6400MHz (OC)" or that some frequencies have (OC) and some don't.
I understand that OC probably means overclocked but what does that actually mean in terms of buying and installing ram?
If I wanted to buy some 6000MHz ram would it be a simple plug and play or would I have to adjust some setting, possibly in the bios, or something even harder?
Thank you.
Thank you.
