can someone help please? not sure if im in the right place.
18 Oct 2002
Smoke-On-Trent
Hi people, A friend of mine at work has a crappy IBM thats linked to the works network. In the back of our warehouse there used to be a backup tape drive in some kind of server type box that now has HDD storage.
Right......Everytime he shuts down the pc, he has to manually map a network drive by typing in the following-
right click My computer.
select "map network drive"
select drive P:
folder: \\10.10.1.20\d$
select "connect using a different username"
Username 10.10.1.20\administrator
Password ********
select ok
select finish
because of this he never shuts the pc down :eek: like NEVER. unless something crashes. Is there anyway to run like a batch file or something to to do this automaticaly?
Any help would be great :)
crag.
just to be sure I would type
net use Z: \\10.10.1.20\share /user:10.10.1.20\administrator ********
should z: be p: ? Thanks for the help buy the way, not wrote a bat file for like 15 years ;)
Ahh Ok...
Open up notepad, type the line
net use p: \\10.10.1.20\d$ /user:10.10.1.20\administrator ********
save it
rename the file from ***.txt to ***.bat
stick that file into his startup folder (C:\Documents and Settings\(user)\Start Menu\Programs\Startup)
I have never had a problem using the persistant switch even with different credentials.
net use X: "\\host\Share" /P:Yes /USER:domain\username password
Obviously you can do it by the command line but, as far as I can remember, not by the 'reconnect at logon'.
M.
