Can someone just check my temps and volts? :)
22 Apr 2006
Arms reach from mouse
Hi
Just having a quick OC play last night, well it was so late I literally just raised the multiplier to 41 and that was it. I know, very crude and lazy, one you could barely call an overclock.
But I was thinking my volts don't look right and since I haven't OC'd since the core duo days I'm not sure what I'm looking for with temps and more importantly... Voltage.
Any comments would be a great help! :)
1.922 V for cpu is crazy high.
I thought that, but then it says 1.220v Vcore Volt, which I assumed was the actual voltage as I'd never heard of CPU input Volt before :/
Is this the motherboard setting it's own voltage for the i5 then? What voltage should I be looking for do you think?
OK so I set the 1.9V down to 1.3 (1.2 is the lowest it will go) ande it wouldn't post, even put the multi back to stock too, so I'm thinking that the 1.9 voltage isn't actually for that function?
So confused.
Also can a mod move this to OC section please? my bad
Haswell chip i assume. In this case, 1.9 is initial cpu input voltage, and this is fine. Your actual vcore voltage is showing as 1.220v. Again nothing wrong here.
