Can someone post the qfix fix please.
29 May 2005
Lazenby near Redcar
Just got home to find both Emilys and my quad rigs have hung at 100% completion, tried to get onto the folding com org. site but its not playing ball.
Could someone please post how to use qfix so I can send in the results.
Upon restarting the client it has started working on a work unit straight away I am assuming it is re-doing the WU it had just completed, dont know how that works with Stanford, if Id get points for doing the WUs twice.
Going to bed now will be up around 12.00 (mid-day Friday)
Hate things going wrong when Im tired.
sculptor :(
No extra point for completing a WU more than once. Why should there be as they've got the results already.
IIRC to use qfix you put the appropriate qfix in the same folder as the folding client then open a command prompt window and navigate to that folder.
Run qfix and it tells you which slot is giving the problem.
Run <fah> -delete <slot number>
Run qfix again
Run <fah> -send all
where <fah> is the name of your folding client. This is for Windows, Linux is probably similar.
If running in Linux, make sure to stop the FAH Processes, or this can cause problems with qfix.
Apart from this, I just run qfix in the client folder that the queue.dat file is held in (cd into the required CPUx folder as required for each frozen client if you are running multiple clients on a single PC).
