- 19 Jul 2013
Can you run through the last mission and set "render.perfoverlayvisible 1"? Keep an eye on it once you get to the bit where you climb up a ladder to get out of the underground, about 1 min after the train crashes
As soon as I reach the top i get massive lag/stutter for a few seconds then it goes away. Big spikes on the graph but before and after its a smooth line.
Ive tried everything at stock, disabled onboard sound, max/min settings, nothing helps...
I think there are other areas that it happens but im just using this as i have a save game near it so its easy to reproduce. Other than these certai. Areas butter smooth, is it something on my side or just a game/engine issue?
Clean install win 8.1
Fx 8320 at 4.8 (300 fsb)
Crosshair v formula z
R9 290
8gb ram
500gb bx100 ssd
Thanks
R9 290
8gb ram
500gb bx100 ssd
Thanks
