Hi Guys,
Just a quick question regards the fan setup in the original Coolermaster Stacker. Im looking to replace the original fans but Im unsure if the 120mm mounts can fit only 25mm or 38mm fans?
I assume the the HD cage can only hold 25mm, what about the mount on the back? I think because of the DFI audio module I might be stuck with 25mm too aswell...
Any ideas? I presume a few have replace them since they dont push much air...
ps3ud0
ps3ud0
