Can Volta run RTX, yes but...
Man of Honour
21 May 2012
Dalek flagship
I thought I would post this as there has been some debate about the Titan V running RTX so I decided to give it a go in the Port Royal benchmark.
As it was just a test to see if the card could run it I only used a PCI-E 3.0 x8 slot on my 24/7 gaming PC, the x16 slots have got RTX Titans in them.
Below are the scores for the Titan V and RTX Titan both are overclocked to make it a fair comparison.
Titan V
https://www.3dmark.com/pr/10155
RTX Titan
https://www.3dmark.com/pr/9088
As you can see the Turing card is more than twice as quick as the Volta card but the latter card can run RTX at about the same performance as a 2060 will.
