31 Aug 2011 at 21:01 #1 galadial galadial Associate Joined 5 Jan 2004 Posts 663 This is what I have: 320 Gb SATA HDD Core 2 Duo 6300 4Gb DDR2 RAM Radeon HD 4850 Old Freezer 7 Pro cooler (first generation) Can you build me a system to play modern games? cheers Pete
31 Aug 2011 at 21:30 #2 R088ieS86 R088ieS86 Soldato Joined 25 Oct 2009 Posts 2,724 Location Northampton Just pop the above in a case with a PSU... or am I missing the point of the question?
31 Aug 2011 at 21:35 #3 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,899 Location N. Ireland R088ieS86 said: Just pop the above in a case with a PSU... or am I missing the point of the question? Click to expand... will need a mobo and optical drive also. PSU - http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-OC&groupid=701&catid=123&subcat=1098 Case - http://www.overclockers.co.uk/showproduct.php?prodid=CA-214-CM&groupid=701&catid=7&subcat=29 DVD Drive - http://www.overclockers.co.uk/showproduct.php?prodid=CD-099-SA&groupid=701&catid=10&subcat=951 and just get a 2nd hand mobo off the MM, or if you want to go really cheap, get the rest of the components off MM instead.
