So I picked one of the boards up online as it was cheap and 1150 socket(got a pentium G waiting to used) and it didn't come with a cooler which isn't a suprise, but it does have a bracket for screw types. Thing is I removed that to fit a stock intel Cooler and it doesn't tighten up nor can you push on the clips, so it looks like I need to get a more suitable cooler.
Can you get aftermarket ones or would it need the original cooler? It's got the pentium fitted, but if all works well then I will look at quads.
