Can you extend filament tube?
11 Feb 2007
London / Essex
Are all PTFE tubes the same size and can you extend them? My ams2 is a bit too far away and im trying to be cheap as there another spare tube with that came with the ams2, or should I just spend the money and get longer tube and if so what would suit the H2D?
You can, but, if you are using macro's etc to feed and retract filament make sure you adjust the lengths accordingly..
I've just moved from an ender v3 pro to the H2D so not really doing anything bar than using Bambu Studio to print.
Thats not a bad jump, I went from the Ender 3 Pro to the Kobra S1, night and day difference..
You planning on using all of the head options?
Yes atm got two ams 2 pros one to each head tried it for special support material but have not had much luck atm, but comes in handy for dual colour prints. Not doing anything out of the normal.
