can you get 8 channel fan controllers
23 Nov 2009
North Leicestershire
don't want to get 2x6's or 2x4's i'd ideally like a 8 channel that takes up 1 bay i've seen them ages ago but can't see them anywhere now?
Do you have to have all fans controlled separately?, could you not have multiple fans on one channel?.
NestleQ make a 8 fan controller in a 2 x 4 arrangement,
Got one myself, had it nearly a year I think, wasn't a perfect fit in my SilverStone FT01, but it does the job well
The blue LED's in it are very bright and annoying, but I just put some black tape over them.
I looked at these but they only start at 6 volts i need something that drops to 3 volts which should give about 25% full power
Lian li do those type but only in 6 channel :(
sunbeam rheobus extreme may be worth looking at
only 6 channels, but 30W(max) per channel, so each can easily handle multiple fans
