I built my own. All you need is a plank of MDF about the size you want your shelf, cut a length off the side and use that to make legs. I used wooden dowels and PVA to hold mine together. Works rather well. Far easier and cheaper in my opinion.
There are plastic risers (£12-£25 ish) you can get but you will have to google as they are sold by competitors. If you want a shelf or riser made out of MDF to match your desk, then you're talking of £30 for a piece of MDF with metal legs up to and beyond £80 for for three pieces of MDF stuck together for a corner desk (googled again).
