Can you guys recommend me some socket sets
Caporegime
27 Nov 2005
Guernsey
Get yourself a bahco set if you will be using them often. Especially if work will be paying for them.
For general DIY use these are ok or if you have a Halfords near by there Professional handtool range is also good.
If your looking for something a bit better quality you could look at Beta (Italian made) , Gedore (German made) but much more expensive.
I can thoroughly recommend Primetools.co.uk and have purchased majority of my handtools from them. They have a pretty decent SALE section too.
Try cromwell tools....
http://www.cromwell.co.uk/category_page/0309
It depends on your use but I need mine for work and wouldn't touch a halfords set if they were given to me for free. I use sockets with enough force to shear 3/8th and 1/2 inch drive breaker bars and I need to have some confidence that they won't split on me :D
Obviously if you are just using them for light use a halfords set will do you fine :)
If you are using them all the time, I would deffo say a Bahco set,
Next best i would say halfords, If its for home or hobbie use a Draper
set would be fine
Valdosta professional. Lifetime guaranty and they exchange on the spot no questions ask. 70% of the time they have online sale as well. Like 50% off.
