Can you help match a center speaker to my fronts please?
25 May 2011
My fronts are Focal 816v
The center is to be placed under my TV. It can't be anymore than 6" in height.
Don't want to spend more than £250 happy to buy used
816v specs
Type 2-1/2 way bass-reflex floor standing speaker, Powerflow.
Finish Moka - Natural
Drivers 6-1/2" (16.5cm) Polyglass woofer. 6-1/2" (16.5cm) Polyglass mid-bass. 1" (25mm) TNV Al/Mg inverted dome tweeter.
Frequency response (+or-3dB) 47Hz - 28kHz
Low frequency point 39Hz
Sensitivity (2,83 V/1 m) 91.5dB
Nominal impedance 8 Ohms
Minimum impedance 4.3 Ohms
Crossover frequency 300Hz / 3 000Hz
Recommended amplifier power 40 - 200W
Dimensions (HxWxD) 39-5/16 x 11-1/8 x 14-3/4"
Net weight 49.5Ibs (22.5kg
I think you might get more success by putting this in the home cinema section; or at least, another way to look at is, if it's 2 places twice the chance of success. :)
