Can you mix and match?
12 Jul 2005
ive got 1GB Geil Ultra X atm - i want another gig but cant really afford another gig of Geil - as such, i was wondering if i can mix and match with another brand?
Thanks guys
Minstadave said:
You should still be ok in dual channel iirc.
"In order to achieve this, the DDR SDRAM memory modules must be installed into matching memory slots, which are usually color coded on the motherboard. Each memory module in each slot should be identical to the one in its matching slot. It's also possible to use similar memory sticks from different manufacturers or different production series as long they are of the same size, specification, the same number of memory chips and internal organization. However, several motherboard manufacturers only support configurations where a "matched pair" of modules are used. For this reason, most memory manufacturers now sell "kits" of matched pair DIMMs."
You may get lucky.
