- 27 Jun 2007
Hi,
So, decided to upgrade my Media Center to Vista Premium from MCE2005. All seems fine and dandy, but yesterday decided to install my wireless USB Netgear adapter (WG111T). SSID is being broadcast so it sees my network, asks for the passphrase/key - have entered it both ways and it accepts it. It just cannot connect??? baffled!!!!!
Have switched off/on router and also disabled firewall but with no luck. Please note that the Vista install is clean so no other software on there. Also, have a second machine running upstairs and it connects with no problems at all.
Also, if I try to find it with the Netgear software, again it finds network, accepts the key but just cannot connect.
Would really appreciate some help on this one
Thank you
Thank you
