Can you recommend me memory that will work with my system?
5 Jan 2005
South East, UK
I built my PC in 2009 :)
I have the following motherboard:
Gigabyte GA-EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
I bought tri-channel memory for it because I read this gave the best performance for this board:
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800 (1600MHz) Low Latency Tri-Channel (PVT36G1600LLK)
If I want to increase the amount of RAM I have what is my best course of action? I read you should not mix RAM types so i'm confused as to whether I can add to what I have (if so what with), whether I should ditch what I have and start over with new RAM, or whether I should not consider buying RAM for this mobo as it's so old i should update to something newer.
Hope someone can advise - please feel free to ask if you have further questions.
Dub
You have 2 choices here try and purchase another set of tri channel memory or purchase dual channel memory, example 2 x 8gb sticks. Your motherboard will run in dual channel mode and ther wont be much diffrence in performance.
