Can you think of a use for a load of SAS drives?
31 Dec 2003
Stoke on Trent
hi all,
I've been tempted to build a homelab as I may be able to get my hands on servers soon, but mainly a tonne of storage in the form of a variety of SAS 2.5" drives.
Is there a technology I could make use of to bundle them all into and maybe try out some of this software raid stuff like Xpenology, Opennas, Unraid etc?
The caddy's will be more use than the drives imo :), unless your after capacity just get some cheap SSD's that work with the raid cards.
2.5 SAS are noisy and generally run quite hot. Not ideal in a home environment.
Oh. Thought there'd be a way of experimenting (labbing) large storage pools.
I get your point about heat and noise, but I have a garage
As above it depends on the size and what you plan on doing with them. Unless you have a very specific reason, it’s usually just a waste of power.
As above power wastage would be the main concern. If you're buying an old server just for the sake of plugging in a load of old sas drives, it'd be significantly more expensive than just buying consumer grade gear.
We haven't designed our storage solutions to use 2.5" SAS drives in at least 6 years. We've had them in the head in raid 1 for the OS and the rest of the storage is bulked out with 3.5" SAS.
