Canned air
Man of Honour
4 Jul 2008
Do OcUK sell this?
I can't seem to find any on their site, which seems odd for a massive PC hardware store..
Am I just being blonde and can't see it?
get a bike pump instead (one of the long stick ones)
one of these
and one of these
cost me less than 2.50 for all of it and works like a charm.
it also doesnt get any moisture in it like the cans of air can ;)
Thanks, not after saving money so just looking for the easy can of air :p
I guess I'll have to go to competitor for this one :-/
Depending on what you want to blow with the air you should think about get some mini/micro vacuum cleaner attachments designed for cleaning PCs and actually get the crap out rather than blowing it around.
The canned air is useful to an extent, but you have to hold it perfectly upright or else the moisture comes out which can be frustrating.. but I use it with no probs
you can pick up the cans in some pound shops, and Asda etc.. but in Asda its like a fiver.. so if you have any of the pound shop chains near you, try there 1st
I bought some of the Dust Off Gaming Gear from OCUK a while back, can't seem to find it now so guessing they stopped stocking it. Works a treat, though.
I bought an air compressor from Aldi for £30, use it for a multitude of jobs as well as cleaning the PC with the same bicycles accessories from above,
one of these
and one of these
What are them two things?
edit: Can you trust me them things?
lol everyone copyin my flow eh xD
just go on any retailer and type "bike pump" get the cheapest there is.. literally a stick is better than the fancy ones
then get a bike adapter which is the picture in hand
i'll trust you if the other guy doesnt but its pretty easy.
also thanks wise man davido labido as you have shown us a real neat trick xD
The one problem with random compressors is they might spit out a bit of oil as well.
not only oil, water as well... because the air contains water.
there is something to remove the water before it comes out, like a filter or regulator.
