Cannot find replacement drive for RAID
18 Sep 2012
Hi All
I've got an old server box here with an Areca 1220 RAID card and 6 WD Caviar RE
320GB hard drives in RAID5. Recently one of the disks died and so far I've not been able
to find a source that stocks them, not surprising they are 2006 era SATA 1.5 drives. Is it
possible for me to buy a new WD Caviar RE4 500GB drive and use that to rebuild the array
(using 320 of 500GB capacity of course)? Has anyone done this in the past and suffered any
negative problems?
Thanks
Although not having specific experience with that hardware, providing your replacement drive is the same interface and RPM speed as the other disks in the array you should be fine. SATA drives are backwards compatible, and I think some have jumpers that explicitly force a connection speed.
You can mix drives with different cache sizes in RAID5, but you may get a slight reduction in performance. Rule of thumb is the array will run as fast as the slowest drive.
