15 Nov 2006 at 17:20 #1 rossyl rossyl Soldato Joined 27 Oct 2002 Posts 4,280 Location London house is connected to cable broadband. then the connection is split by using a router. People are connected wirelessly and by wire. Some websites such as facebook will not load on anyones machine. Any ideas how to fix it?
15 Nov 2006 at 17:26 #2 rossyl rossyl Soldato OP Joined 27 Oct 2002 Posts 4,280 Location London run spybot still no help.
15 Nov 2006 at 17:28 #3 Uhtred Uhtred Soldato Joined 18 Oct 2002 Posts 6,372 Location Bedfordshire try plugging a pc direct into the cable modem and see if you still get the same problem
15 Nov 2006 at 17:36 #4 rossyl rossyl Soldato OP Joined 27 Oct 2002 Posts 4,280 Location London same prob
15 Nov 2006 at 17:51 #5 MAllen MAllen Associate Joined 24 Feb 2003 Posts 2,236 Location Brighton, UK Check for parental filtering in the router. Some new routers (i.e. Netgear) come with this kind of feature.
15 Nov 2006 at 18:47 #6 xolotl xolotl Man of Honour Man of Honour Joined 9 Nov 2004 Posts 2,140 NTL? I've been having DNS errors for the last week with them. Getting very annoying now.
16 Nov 2006 at 23:46 #7 Bomag Bomag Associate Joined 5 Nov 2003 Posts 1,035 Location Leeds If you are with NTL look at http://homepage.ntlworld.com/robin.d.h.walker/cmtips/trancache.html#ntl One of my PCs is always set to an alternate proxy server (currently manchester1) Last week NTLs normal proxy would not give me access to HP.
16 Nov 2006 at 23:52 #8 danieln1 danieln1 Associate Joined 9 Sep 2006 Posts 153 Location Nottinghamshire try treewalk http://ntcanuck.com/ if you can get there its small dns services makes loading pages lot easy plus if your havening dns problems no need to worry with this
