can't access 2820 settings
  • Thread starter Thread starter Ish
  • Start date Start date
Ish
Ish
11 Jan 2006
West Midlands
Hi
I have a Draytek 2820 router and for some reason I can't access the settings page any more either locally or from the internet anymore.
It was working fine before.
I have tried powering the router off for 30 seconds but this hasn't helped.
I don't want to hard reset the router yet as I don't want to lose all my settings.
What else can I try?
Have you got a static IP or is it assigned by the router? I believe some routers will only allow you to connect to them if your in the same IP range as they are.
