Cant connect to AnyDesk
6 Jan 2006
Newcastle upon Tyne
Hopefully this is the best section for it as it falls into multiple areas of the forum potentially but Ive been unable to use AnyDesk all day today. It was working fine yesterday when I used it.
Their webpage wont load from my computer (hard wired to router) or phone (over wifi) however if I turn the wifi off on my phone and connect via 4G it loads the website no problem.
I get the below message when trying to connect to their website:
The connection for this site is not secure
anydesk.com sent an invalid response.
  • Try running Windows Network Diagnostics.
ERR_SSL_PROTOCOL_ERROR
Can anyone suggest what the problem may be or anything I can try? Nothing has been changed at my end that Im aware of.
I guess something is trying to redirect you via DNS and the certificate isn't valid - what happens if you run "nslookup anydesk.com" in a command prompt
Ive just managed to get to the bottom of this! Turns out Talk Talk had re-activated their "scam protection" on my account!
