Can't connect to LIVE
10 Feb 2009
Leicester
Hello,
I have a problem connecting my 360 to the internet via wired. I use the same ethernet cable for my PS3 and when I plug it into the back of that it connects to the internet straight away but when I plug it in the 360 I get the message "Can't detect network hardware".
I have reset my router, hard reset it, entered 360 mac address, turned off router for 30 seconds and still can't connect? Help?
Update: Manually entered my internet settings, Used the same MAC and IP address as my PS3, still isn't connecting, even tried giving the 360 its own IP address.
have you gone under system settings and got the 360 to scan the network - mine didnt work until i did that.
it could also be that your router is not giving it an ip address.
How do I make it scan my network? Cause when I go into network settings it just has "Configure Network" (Everything is set to automatic), Test PC Connection, Test Internet Connection & Something else, It just instant fails when I test PC and internet.
