I have a Virgin Superhub2 which is in 'Modem Mode' connected to an ASUS RT-N56U which im using for a wireless router (as the wireless on the superhub is rubbish). Now the IP address for the Superhub2 is 192.168.100.1 which i can connect fine to when i have my ethernet cable running from my PC directly to the Superhub. As im using the ASUS for wireless the ehternet cable from the PC goes to the ASUS first and then another cable to the Superhub.
With this setup i cant connect to my superhub when using the 192.168.100.1 ip address!. Im able to access the ASUS and also an 'Access Point' ethernet router i have down stairs in the back room (have a 15 meter ethernet cable that runs down the outside of the house and then back in to the room downstairs) just fine. Both of these im able to access the settings menu from my main PC but for some reason when i try and connect to the superhub i just get a connection timed out screen, any ideas why i im having this issue?
