- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
Hi all,
Just routed 7m of cables through the floorboards to get ethernet to another room and having an odd problem.
Setup
1) I have a 24 port switch under the stairs that connects to the router
2) I have an 8 port switch in the new room
3) I've then connected from the 24 port switch to the 8 port switch and from the 8 port switch to my TV and there's no network connection.
When I take the switch out the equation and plug directly into the TV everything works great, so I know the switch is the problem.
Strangely I've been using this switch for about three years without problem and just moved it upstairs when I was doing this.
Are there any issues with daisy chaining switches or configuration problems that could be causing this?
Both are Netgear powered switches.
Setup
