Cant Deal With It AnyMore....BSOD
2 Oct 2007
Uttoxeter,Uk
You ever hate it,When your PC work nice and smoothly night before.Then when i turn it on this morning,then i get every BSOD throw at me.It started with Graphic Display disappear,when in Windows Classic Mode then BSOD like some of these :Non-Executable Memory (FC)
System_Service Exception (3B)
Page Fault In Non Paged Area (5D)
CI.DLL
Data Stamp 47besbb6
Driver_irql_not_less_or_equal
(7E) Etc.
I don't see point Windows Error Report and Solution since they never solution for your problem.
I Check Windows update and Site update.
Its happen couple time before,couple months back,i don't no what did to stop it before,but i just give up.No matter how many time try to fresh install i still end up BSOD.
Here My Specs:
Os:Window Vista 64
Cpu: AMD Athlon 64 X2 5200+ 2.6GHz Socket AM2
MotherBoard: MSI K9N SLI-2F, nForce 570 SLI, DDR2,
Socket-AM2, 2xGbLAN, ATX, 2xPCI-Ex16
Cpu Cooler: Thermalright Ultra-120 Extreme With Scythe S-FLEX 1200RPM Ultra Quiet 120mm Fan
Psu: Ocz 700Watts
Ram: Corsair 4GB DDR2 XMS2-6400C4 TwinX
HardDrive: 2 Western Digital Caviar SE16 400GB SATA2,Ex WDC 240GB
VideoCard: Msi 8800 GTS OC
Screen:Samsung 22" LCD Syncmaster 226BW
KeyBoard,Mouse And Speaker.
Plz Help!!!
Unfortunatley that error can be caused by many different things, run chkdsk on the hdd and memtest86 on the ram. Update all drivers to the latest versions and make sure the pc is not overheating.
Duff memory, memory not running at its correct voltage, or not enough chipset voltage if running 4 sticks is often the culprit.
yeah am running 4 single stick,i have put ram voltage up to 2.10v as it say on the ram.but then i was looking around the forum,i found if putting cpu Voltage up 1v something should do it or something.my bios is updated.or any got same MB as me what Ram Voltage and chip or cpu voltage u put on?
am ready started fresh install with 1 stick in at mo.
I think you mean 0.1v not 1v. Thats doubling the CPU voltage . . .
And its the Northbridge voltage you want to increase. Could also be called G(MCH)
is this right,i put my 4gb in now from fresh install and sp1.i couldnt find Northbridge voltage or MCH in the bios
plz say anything if right or wrong?
I dont even know that BIOS, ive never even seen one similar to that before so cannot help on the BIOS options im afraid.
Everything seen to be working,for now.no bsod.i just change my ram into different slots.i can remember when coming on post boot,it was on dual channel and now its on single channel eveything seems to working now.
thanks for all u time and help.:)
