Can't decide between Razer mice
wsh
wsh
18 Oct 2002
I've narrowed my search for a replacement for my trusy wired Intellimouse Explorer 2.0A down to these two:
Razer Imperator 5600dpi
Razer DeathAdder Respawn 3500dpi
I can't decide which to go for? Which is comfiest with the palm grip? Which do you recommend? Has anyone tried them both?
I just got myself the Naga Epic after i got the normal naga a month ago, Either something is wrong with mine (keeps freezing under wireless mode) and the lift off is bad.
The build quality seems terrible on the newer razer mice compared with the older models, You might be better off going for the roccat.
Got the DeathAdder myself, and I cant recommend it enough. Very comfortable, no complaints :). Had it for a couple months now..
EDIT: My bad, I do indeed have the respawn. Again, cant recommend enough :D
I have the Imperator myself. It's literally perfect for a claw grip tbh. Palm grip works fine as long as you're hands aren't too big like mine. :D
I've never had tracking issues or anything with the laser either, despite so many peoples complaints about it.
I'd best get the DeathAdder if the Imperator is for a claw grip. I've seen the black edition with the shiny plastic sides replaced with rubber and a black scrollwheel. I think thats the one I'll go for.
My old Deathadder keeps freezing and being jerky even after driver and firmware update. I'm going to avoid Razer and go with Logitech as their support is meant to be top notch.
