can't decide between the opty 165 and 3800 x2
12 Mar 2006
N.E England
spending 200 would be nicer on my wallet but the opty 165 sounds very nice indeed, what would be best bang for buck atm? :confused:
so the 3800 would be the better buy at the moment what about the extra cache on the opty cpu will i see much difference etc?
The extra cache on the opty is the same as an extra 200mhz.
The opty 165 runs at 1.8ghz and the X2 3800 runs at 2.0ghz, so they give out the same performace when at stock.
I would go for the X2 3800+ as these are good clockers and cheaper.
i think i may aswell go for the 3800 then!
you would need to be running a decent mobo probably a dfi to get the decent clocks from the opty 165 because it only has a x9 multi compared to the 3800x2's x10.
