Can't decide - Rajintek Ophion or Metis Plus?
20 Jun 2005
London..
I've been looking at both of these cases:
I prefer the look of the Opion (full clear side window), however I prefer the size of the Metis.
I have seen it's easy to mod a perspex window onto the Metis, so I could do that.
The other major difference is that the Ophion takes a smaller CPU cooler vs. the Metis, but a larger GPU.
With a SFX PSU the Metis can take a ~260mm GPU. I have watched quite a few reviews and there are concerns on the Ophion in terms of cooling if not setup correctly, but I am sure this is probably the same with the Metis.
Which one is the better case overall taking into account cooling/working with?
What about the Cougar QBX?
Out of the two, I would go with the Ophion. I had the Thetis that was ATX sized and while okay, somewhat a challenge to build in and get the airflow right. The Ophion looks better airflow wise.
Just had a look at the Cougar QBX - I didn't know about this one. It looks good, however not to keen on the aesthetics (and I wanted a window).
So it's still between the two Rajinteks...I am kind of leaning towards the Metis for the bigger CPU cooler and more compact size..but still not set!
What about the Jonsbo A4?
Yeah the next step up is really the cases without much stock/ hard to get. What CPU cooler do you have/ planning to buy? Also, which CPU do you have?
Jonsbo A4 is a bit to pricey for me (Ophion I can get second hand at around 1/2 the RRP).
Planning on running a Ryzen 3600 and potentially a 5600x in the future - I was planning on going with the stock cooler for now.
I would go with the Ophion then! At that price, with the better cooling, layout and (IMO) looks.
One thing I did is measure out and create a cardboard cutout of cases I'm interested in (I settled on a NZXT H1 in the end) to see how they would look in the space if that helps deciding.
