I'm looking at buying 2 x 19" Widescreen monitors, but I can't decide which ones to go for. I would like to use the monitors for gaming and for design work, so clarity and colour is important. As mentioned I would like to buy 2 of them, to be linked up as dual monitors. All monitors under the 19" section are in my budget. Personally I like the look of the Acer 19" P193W-D, but I'm not sure if spec wise, it's any good?
Thanks,
Hessian
Thanks,
Hessian
